HELP - How do you remove disc rotors
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Dec 10, 2001.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Ok, Do i need the special tool to remove my rotor? or can i do it without it?
    My 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a> 350/TH350/NP203, Q-jet, Edelbrock intake, Vortec heads, 4" lift, and 36" TSL's
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    You need a big four prong socket to remove the two spindle nuts. I dunno if you can rent them at Autozone or Checkers. I know they have the ones for Fords. They don't cost too much if you need to buy it. And probly a dental pick or "candle shaper" to remove the snap ring for your locking hubs.
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  3. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    hub socket for a chevy 4x4. Should be about 15$ or so. Snap ring plyers will help, but arent mandatory if you have a pick or something small to get in the holes. Also, if you are trying to get your roter off of your hub... put an old lug nut on top of the studs and drive them out with a big hammer (that is, once you have everything off of the truck).
    Sparky
    When all else fails... Check the blinker fluid.
    78 K-5
  4. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    ???? I'm all corn fused about your reply. In order to remove the rotor from the hub? Oh wait I see where your coming from..... I was thinking the spindle. I'll go back to sleep now![​IMG]
    Jim
  5. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    Thanks for the help everyone. I got it off and got my lug studs all changed out. Now i dont have to worry about my wheel falling off
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Nice to not have to worry about that...it sucks when your wheel falls off of your truck[​IMG]
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
