HELP how to adjust TV cable and mount hood pins
Discussion in 'The Garage' started by camokrawler, Apr 1, 2006.
  1. camokrawler
    camokrawler Registered Member
    Mar 2, 2006
    47
    Central North Carolina
    I just put on a trick flow TBI spacer on my 87 truck and am having problems getting the TV cable adjusted right. any suggestions. also i purchased some mr. gasket hood pins so i dont have to deal with my finicky hood latch anymore and was wondering if anyone had some good installation tips or ideas. thanks.
    camo krawler
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    i was told by gm mech that full throttle no slack in cable. so motor off hold full throttle and pop the latch and adjust it to no slack. or if any just a tiny bit of slack.
    fix it correctly or quick death of a 700 r4 will falow.
  3. Orange Crush
    Orange Crush 1/2 ton status Premium Member
    Mar 6, 2003
    440
    St.Stephen S.C. 29479
    If you do any wheeling/flexing skip the hood pins. I have to replace my core support because I ran them for a little while and the core support cracked all around the pins.--Eric
  4. ryoken
    Jun 13, 2003
    29,621
    1,371
    Jersey Shore
  5. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
  6. 89K5guy
    89K5guy 1/2 ton status
    Jul 11, 2005
    174
    Ohio
    I understand how to adjust for the factory setting but years ago i owned a 1987 350 IROC and when i bought it the trans shifted rather sluggish.My buddy (GM mechanic) told me about adjusting the TV cable.I did this and then moved the slider (i can't remember which direction now)and the trans shifted vey hard and firm:D .I drove the car a long time with no prolems.So FINALLY my question.CAn i manually adjust the TV cable on my 89 K5 to shift a little harder without damage to the trans?I know that a sloppy shift after adjustment is bad but what about a harder shift adjustment?
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    In that article it states that you don't adjust a cable, you 'set' it to the only setting that is correct. Adjusting will just eat your trans as far as I know. Read through all that article if you get time, it's very interesting.
  8. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    All the way out at wide open throttle,about an eighth or quater inch at idle
  9. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    Keep doin the research and make sure the geometry is right.I think I had read somewhere that if you adjust by the way GM tells you then it will not be enough pressure.It's been a good while since I fooled with mine.Good Luck!:D
