Help!!!!! how to get ring gear off of carrier
Discussion in 'The Garage' started by sandawgk5, Sep 26, 2005.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I tried putting my ring gear on and my dumbass did not get the bolt holes lined up just right and the bolts do not start. SO how do I get the gear off it is a really tight fit and I will have to heat it to get it back on. If I use a punch in the bolt hole to tap it off will it damage the teeth or do I have to use a press or something.
    Ira
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Use a punch in the bolt hole. Alternate sides like tightening a wheel. Just be sure to not FUBAR the threads.
  3. readymix
    May 30, 2004
    6,706
    26
    Should'nt you be at work :haha: :haha: :haha:
    like me :D
  4. sandawgk5
    Oct 28, 2003
    6,881
    I am. Tax dollars hard at work. The boat I control maintenance on is depolying in 1 week so we are all wrapped up and just passing the time till she leaves.
    Ira
  5. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    maybe your axle is diff, but my front 10 bolt just needed a couple well placed wacks with a 3 lb mini. then i just worked my way around with a couple screw drivers.
  6. sweetk30
    Nov 1, 2004
    25,554
    548
    horseheads , ny 14845
    if you break the detroit i wont warrenty it:mad:
  7. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I use a brass hammer.
  8. sandawgk5
    Oct 28, 2003
    6,881
    No, it is only in the carrier "to keep the dust off of it" :D . I was trying to start the bolts when I moved Roz the other day as it was at his house and I seem to have misaligned the ring gear :doah: Is it possible to break a detroit for a 14FF? :dunno:
    Ira
