HELP!!! how to seperate lower ball joint from spindle 2wd.
Discussion in 'The Garage' started by Jonny-K5, Jul 3, 2004.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i've been trying for over an hour with a pickle fork. it wont budge, i've got the top one seperated but the bottom one is frozen.
    i've got a service manual that says to use a special tool that spreads both balljoints apart, but i dont have anything like that. any other methods?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Get a pickle fork that you can use with your air hammer if you have one. If not, get a bigger hammer.
  3. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    [/ QUOTE ] bigger than a 15lb sledge? it doesnt make sense to me causs the other side just fell apart, i didnt even use the fork. i dont know why this one is such a pain
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I usually just leave the nut on just barely on the top of the ball joint threads, and letting the spring keep downward pressure on it, and hit it with a BFH, several times, they usually,,,well have always popped off.
    After a few or several swings of course, and i only used a 5 lbs.
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I have never used a fork
    like above, pressure on it with a few good smashes with a BFH against the side of the casting
    have the snapon reamer handy to repair the tapered hole when you deform it
  6. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    i tried hitting it on the casting as well. i dont know whats up with this thing, its welded in there. i might try using a torch to loosen it up, then whack on it some more. reason im doing this is to replace the whole works with dropped spindles and disc brakes, so i dont care what happens to the spindles, as long as the control arms are undamaged.
