Help! How to take the intake manifold off
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by linksvu, Jun 30, 2006.
  1. linksvu
    linksvu Registered Member
    Jan 7, 2006
    89
    Littleton, Colorado
    Alright, so I am stuck. I have everything removed from the intake manifold, and all the bolts removed. However, the thing is stuck so well on there I can not, but any force of mine, get it off.
    I am reluctent to stick a pry bar under it and go at it as I am worried to damage the flat surface or mis-shape the manifold itself.
    Any thoughts?? I hope I do not have to remove the hood and tie a lift to it...
  2. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Try taking your valve covers off. They could be holding the intake down. then get a screw driver and pry on it. if that don't work make sure you have all the bolt off.
  3. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    big prybar and pry with it. :D
    if you are scared of the surfaces beeing warped by this . then do it at the ends. as thay just get the good old thick bead of rtv anyways.
  4. wicked87_k5
    wicked87_k5 1/2 ton status
    Aug 9, 2004
    235
    Little Falls,NJ... North
    What they^ said prybar is the way to go just make sure your valve covers are not hanging over the edge of the intake
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Did you remove the dizzy:D .
    J/K
    Like everyone has said a prybar that is the only way I have ever seen them removed. If it has been on a while the gaskets and rtv like to seal pretty well:D .
    Ira
  6. linksvu
    Jan 7, 2006
    89
    Littleton, Colorado
    I did get if off, thank you though. Still a pain, but got it
