Help - Hub Lock washer
Discussion in 'The Garage' started by BowtieBlazer, Jul 10, 2002.
  1. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I had hell finding just the lock washer to go between the first axle nut and the locknut....bought new nuts and washer for it as a 10 bolt - D44 kit about 6 months ago....got the outside lock nut off and now the washer won't come of for anything. Its one of the ones with holes in it on a 10 bolt front. Tried pliers and needle screwdriver pics. Any advice / tricks? Got a wheel bearing that needs attention ASAP its clicking!
  2. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Make sure it hasn't slipped out of the keyway, if it has twisted at all then you need to straighten it back into the keyway and it should pull right out, it helps if you push the hub inward while you try to get the washer straight in there. Good luck
  3. BowtieBlazer
    Jul 15, 2001
    2,462
    Didn't look like it was bent much if at all...must be though....now that I think about it three of four sides move...the side (round washer of course...doesn't have sides but make in squarwe in your head) that doesnt move is the keyway. Its like it found a new grove there. It appears to be lined up but aint budgin!
  4. BowtieBlazer
    Jul 15, 2001
    2,462
    just spent another 10 minutes playing with it again with no luck. The keyed part still seems to be stuck...its 10pm here and I have to be up for work at 6 so I am calling it quits for the night...2hrs working on a washer SUCKS! guess I'll take my other truck to work in the morning...fingers are about to bleed from trying to "feel it out and off"...getting really frustrated too...
    Still Need help any suggestions?
  5. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    The number one tool I have ever found deeling with hubs, is a "Radiator Hose Remover" If you don't know what this is, it looks like an ice pick that has been bent four or five times! It's used to seperate baked on hoses from the housing so it all comes off in one piece, but I've found a thousand uses for this tool! Other than that, a lot of patience and a lot of pounding!!! Unfortunately, sometimes I have to break things in order to properly fix them! /forums/images/icons/smirk.gif
  6. BowtieBlazer
    Jul 15, 2001
    2,462
    yep looks like I will be breaking this soon enough to fix it. Never heard of the radiator hose tool is that a specialty tool through snap on or something?
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    are you using a pick set?
  8. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I have used two small jeweler's screwdrivers (can be picked up as a set for $5 at the local hardware store) to remove them. Stick one in one hole and the other in a hole 180 degrees from the other and and hold them at an angle toward each other and pull out. I've had a few stubborn ones that I've used this method. Others I have just used my fingers.
  9. trailblazer87
    Jun 11, 2002
    707
    Madera, CA
    If you can find set of looooong skinny needle nosed pliers you can sort of work it out of there, try a telescoping magnet also, just try not to stick it to anything else /forums/images/icons/tongue.gif
  10. BowtieBlazer
    Jul 15, 2001
    2,462
    yeah tried a pick set already didnt work.. I ended up using a clothes hanger I cut and bent to suit my needs hook shaped so when I passed it through it hooked around the lock washer. Came out with LOTS more pulling tugging and swearing. Turns out there is a raised part in the keylock channel part of my spindle that it was seated behind!
