HELP! I can't get some wheel studs installed in my durango
Discussion in 'The Lounge' started by DesertBlaze, Apr 5, 2006.
  1. DesertBlaze
    DesertBlaze Registered Member
    Sep 19, 2005
    13
    New Mexico
    So I took my Durango off a couple jumps. I ended up snapping 2 wheel studs in my rear right tire. I got the studs out with out any problems. I went to checkers, bought some new ones, and they ended up just turning to **** trying to put them in the hub. So I drove alll the way to the dealer, got the actual studs, and I dont' want to screw anything up. I don't have an impact wrench, so I was doubling up the nuts, using a big one to go around the stud, and then a lug nut to go over that and pull the stud through. BUT ITS NOT WORKING!!! Help...you guys better have some tricks!
    I tried a giant C-Clamp: that was no good
    I tried just using the tire and pulling the stud through with a breaker bar: no luck
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I use my hydraulic press. :cool1:
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Pull the axle shaft and put them in with a press
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
  5. CustomChevy
    CustomChevy 1/2 ton status
    Jun 29, 2005
    4,328
    Kitchener, Ontario, Canada
    AHHHHHHHHHHHHHHHHHHHHHHHHHHHH
    to much tech
  6. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    if you read in the disk brake conversion write up it is explaned the tourqe needed to pull the stud thru is FAR more that it is ment to be aplyed, you could snap the studs just driveing down the road.
    BFH
    or press them in, oh and tech in the gerage, some of us are trying to get druck, and dont need this :D
  7. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    :haha: :haha: :haha: :haha:
  8. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    Freeze the studs.
    Throw the hub on a hot plate.
  9. boggerless
    May 26, 2003
    22,728
    96
    you forgot the vicks vapor rub part.:mad: geez
  10. kyser_soze
    Sep 4, 2004
    3,180
    KC Missouri
    Or the vasoline for taking a wrong turn.:D
  11. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Those words don't belong in the same sentence.
