help, i have my steering column out
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RESTORE89, Jul 21, 2001.
  1. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    i took the steering column out between the rag joint and the firewall to replace what i thought was a bad lower bearing, but the bearing is in great shape, it is bad between the bearing and the neck coming out of the firewall. i removed the retainer clip and pulled of the little metal cap, and ther is a white plastic sleeve inside the neck, but the outside of the bearing does not touch this sleeve except at the very bottom, am i missing a part or is this thing suppose to be loose???
    anbody that has any experience with this please help, i wanted to drive it home tonight!
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
