Help, I need a good Jeep website or help from anyone that knows Jeeps
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1986Blazer, May 27, 2002.
  1. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    I am fixing up a friends 1994 Jeep Cherokee 4.0 Ltr straight 6 cylinder (104K miles), auto tranny & 4X4. I either need a good Jeep site I can post this question or help from some of the guru's on this board that may know the problem.
    The damn thing runs fine (plenty of power, starts fine, not knocking and no obvious electrical probs). However, once warmed up, it will stall for NO APPARENT reason. It is like someone turned off the key. You can restart it in neutral real easily. It only stalls when coasting (like when comming to a stop light or when slowing to take a turn) and it does not do every time. I have replaced the dist cap, rotor and all wires and spark plugs. The coil is running to spec according to the ohm meter. The Ignition Control Module (well, I can't find it) but a local mechanic says it is a very expensive unit, and it is not like the GM HEI module.
    I am at wits end and really need to try to get an answer. The local Jeep dealer here has hooked it up to their diag machine and found NOTHING. Maybe that is because it only happens when you are running the vehicle and not at idle in a garage.
    ANY help is welcome.......I'll even buy the beer should you make it this way!
    Chris
  2. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    wrong forum bud...sounds like somethin to do with the ECM
    NITRO
  3. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Go to the top of the page where it says VOTE FOR THIS SITE and you should be abel to find a bunch of Jeep sites there.
  4. 1986Blazer
    Jun 13, 2001
    511
    Thanks Cory.....I should have known that!
  5. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
  6. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    Try Colorado4x4.org
    Good group of people on there.
  7. greybeard
    greybeard Registered Member
    Sep 29, 2000
    43
    Dallas, Texas
    Off the top of my head, I'd say TPS or EGR valve. Try Jeepsumlimited as BlazinOR suggested. You might also hit www.NAXJA.org. FWIW.
  8. bigblue86
    bigblue86 Registered Member
    Jan 11, 2002
    53
    East Texas
