Help I need info on u-joints
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Highlander, Aug 19, 2001.
  1. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I went to replace my rear u-joint today guess what it isn't the right one mine has inside clips on the shaft and two clamp things on the other But the clamp side is shorter than the press in side and the caps are smaller too. I went two four parts stores even NAPA I still haven't found the right one yet!!! Any info will help a part # would be great.
    I'm running a 83 with 700r 12bolt and dana 44. The Blazer came with a 305 but it's got a 350 in it now it also came with 10bolts too. Now I didn't change all this I bought like this.
    Thanks for any help in this pain in the A$$!! Eric
    <a target="_blank" href=http://cethern.tripod.com/erics-home-page-and-other-stuff/>http://cethern.tripod.com/erics-home-page-and-other-stuff/</a>
    AMSOIL Dealer # 529948
    Cethern@interfold.com
  2. Liberator
    Liberator 1/2 ton status
    Jul 16, 2001
    276
    Communist California
    You need to measure the cap diameter and the distance from cap to cap on each end of the joint. Once you have those measurements convert the fractions to decimals and find the correct conversion in a u-joint catalog that your local parts store will have. My 12 bolt used a Spicer 1310 and I believe newer than 81 trucks used a Sawginaw S-44. That may be a good starting place.
    If it breaks, it wasn't good enough!
  3. Highlander
    Nov 25, 2000
    1,204
    Lakewood Colo
    Yea we did that the clamp side is 3.240/ the clip side is 3.635 And i've gotthe cap dia, also I did just call NAPA he didn't have the 1310 in but will have it monday so will see if it's the odd ball. speaking of that do you remember if ether one of those were odd shaped by chance?
    Thanks for your input Liberator. Eric.
