help identify a noise, plus some other ?'s
Discussion in '1982-Present GM Diesel' started by rocky4by, Oct 12, 2003.
  1. rocky4by
    rocky4by Registered Member
    Oct 7, 2002
    48
    IN
    help identify a noise, plus some other ?\'s
    I've been driving my new CUCV for a couple of days now, the first couple days it sounded normal, just your typical diesel, all I did was change the oil and the airfilter. Now it has a big base sound(sounds like you have the aircleaner lid upside down in a big block Chevy with your foot on the gas)Can't hear each other inside the truck anymore. It does need a new exhaust but I didn't see any leaks. Where's the best place for a new exhaust, like an aftermarket setup or some NOS? The noise seems to be under the hood and almost immediately when you give it gas. Also looks like it has a small front lower pully(crankshaft)leak, unless this is just the front lip of the oilpan, how hard of a job would this be to tackle? Which book would be best to help me out with future problems?
    Thanks for any info.
  2. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Re: help identify a noise, plus some other ?\'s
    I ain't no Diesel expert, but I will try....
    Is the air filter housing seated properly?
    When you reinstalled the air breather system, did you put the "muffler" back on? It looks like a big black muffler that goes between the air breather n the air inlet on the body. Usually held down by a U shaped piece of metal. I don't think that would be enough for you to not hear each other in the cab, though.
    What side is it coming from? Did you check your exhaust all the way from the block to the exit? Have someone get inside and give it a little skinny pedal and see where it be coming from.
    I was running wide open exhaust for a few months and you couldn't hear yourself think it was so fricken loud!! Heck, it was so loud you couldn't even hear the Boggers hum go down the road!! /forums/images/graemlins/rotfl.gif
    No idea on your oil leak. I just let mine drip if it wants to. Its called "Marking your territory" /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    A fresh air filter will always make a 6.2 sound louder for the first couple hundred miles. It's nothing to worry about.
    Did the old air filter you pulled off have a foam wrap around it? This option is available for 6.2 air filters. It acts primarily as a pre-filter but also deadens the sound a bit more than a filter without the wrap.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Good call I didn't think of that one.
    /forums/images/graemlins/thumb.gif
  5. tRustyK5
    Jul 23, 2000
    36,168
    1,366
    E-town baby!
    I turned my stock air cleaner housing into a big open element filter (long story...) and it's damn loud now...I hope I can find my spare housing and put that one on soon.
    Rene
  6. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    No intake silencer on a CUCV. Matter of fact, no hood insulation, firewall sound deadedner, interior carpert/insulation, rear panels...eh? /forums/images/graemlins/ears.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  7. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    WOW!! I thought they all came with the same stuff the civy version had!!
