HELP....identify these heads??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by twenty_below0, Sep 4, 2001.
  1. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    OK, just got a call from a friend that has these heads for sale...there suppose to be from an older 327 the numbers are3795896 andthey have gm 18 on them and in the middle they have E264 or ez64 cant tell if it is a 2 or a z any info would help chamber size etc. THX MIKE
  2. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    these heads came on 64-72 283s,307s and 327s. they are a base head with usually 1.71 and 1.50 valves. 72 or 76cc. not for high performance at all. 2 barrels on top of these always. hope this helps some.
    Neil H.. Alabama.. '78 K5 400ci 4x4 AT,AC,PW Cheyenne. '74 C10 3spd/floor 250ci 4x2
  3. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    i tried looking up the numbers you gave and i didnt find any info. the number needed is the 3 digit number on the edge between the domes and the exhaust ports (in the center i think). if they are 327 heads they should have a 040,041,126,186,441,461, or 462 stamped on them! chamber volume as follows: 64cc found on 040,041,186,462 76cc found on 126,441 and 62cc found on 461
  4. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    the 041 and 441s came only on 68-69 327 and 350s also.
  5. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    If the numbers are correct, he's got 896 heads. It's the last 3 of the P/N. For example, *uuuh*..392717186...*uhhh - thump* that woul be a 186 head (for the record, not Super H.perf, but not a bad head at all)
    So, you guy's looking at the books, check out the number 896. That should also be located under the number 2 or 5 intake runner. and the number should be spelled out completly under the valve cover.
    <font color=purple>In accordance to the prophecy.</font color=purple>
    <font color=blue>Twiztid</font color=blue><P ID="edit"><FONT class="small">Edited by Twiztid on 09/04/01 10:12 PM.</FONT></P>
  6. twenty_below0
    May 16, 2001
    436
    THX I appreciate the info and it looks like I will be passing on these heads...sure is great to be able to ask and have a bunch of people respond in ample time thx again Mike
  7. Nonesuch
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    i cant find anything on 896's. hope some body else has some luck
  8. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    3795896 used on:
    '63 - '67 283
    ''68 - '72 307
    E264 is May 26, 1964 casting date - heads were on a '64 283. As noted earlier, small valve heads, not good for performance.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  9. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    I could never remember those casting date tricks..darnit!.. hehehe! I have several good small block reference books. Guess I need to read em more often.
