HELP ! identify this F.O.D.*PIC*
Discussion in 'The Garage' started by K10ANDYKHAMNIC, Oct 16, 2002.
  1. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    so im changing my oil on my 20,000 mile or so crate engine and i pull the plug and after it is empty i look and what do i see ?? a piece of some kind of metal !!! i have the one peice rubber pan gaket and ive taken it off before but i dont feel like doing it again and risking it leaking and not being able to get one before this weekend ! big dawg safari in truckhaven ,so cal .
    i found this in the oil pan , now that i have it out and there was nothing else in there can i put it back together and go or not ? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    Re: awwe crap ... help !!
    put new oil in it and let er eat...
    ya got a warranty dont you?
    Later
  3. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    thats a serious dick in the butt, maybe it is just part of the casting, im being hopeful here, that the oil circuated to the oil pan. but that is a real ouch, id be pissed, id probly put oil in it, run it, get the gasket, drain the oil back out, figure out whats wrong, put it all back together, and hope for the best, good luck . /forums/images/graemlins/thumb.gif
  4. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    nope , it sat for awhile and so i am out of years on the warranty , it isnt a daily driver . i "might" be able to push for it and win , if it does go , but i doubt it /forums/images/graemlins/frown.gif i think ill just go pull it off and have a look see /forums/images/graemlins/angryfire.gif
  5. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    well i got it out and i have no idea what the heck it is ,someone please identify this thing for me please !!
  6. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    Re: identify this *PIC*
    Looks like a dime. I dunno what that other thing is. ;-)
  7. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    thanks jeffro /forums/images/graemlins/thumb.gif , i wonder who put that damn dime in my pan. ..... /forums/images/graemlins/angryfire.gif
  8. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    bump for my engine
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    which engine do you have?
    does it have roller cam or rockers?
    looks to small to be part of normal hyd lifter
  10. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    /forums/images/graemlins/blush.gif /forums/images/graemlins/rotfl.gif
    Couldn't resist. /forums/images/graemlins/wink.gif
  11. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    an 81, 305 stock crate engine ,gm goodwrench 305
  12. Grim-Reaper
    7,385
    Atlanta
    I'm with MJ......looks like part of a lifter to me.
    Is the engine still in warranty? I would call GM and send them the picture. Tell them to extend the warranty or have the local deal pull the motor down till they find out where that came from. If that is part of a lifter that lifter might come appart and trash the cam. It may have already trashed the lifter bore.
  13. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    I also would say that is the retatining clip from a lifter. I don't believe the lifter will come apart though unless you have too much valve lash. All it does it keep the plunger in the lfter when the lifters have no preload on them. It darn sure needs to be changed.
    If you change it yourself make sure you leave the valve train in tact, just take off the intake. If you loosen the rockers you are liable to release the plunger and anti pump up spring into the valley causing more parts to be floating around somewhere. Find the bad lifter, turn the engine so it is at the top of the lifter bore, clean it off, wrap some duct tape around it to contain the parts, then slowly back the rocker nut off, pull the lifter out, take it to where you got it and ram it up their butt. Seriously, doesn't sound like an error on the builders part. Good luck.
    John
  14. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I'm with John and Grimmy...that's the retainer thing from one of your lifters.
    Rene
  15. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    i'll second the hydro lifter. looks like the little lock ring in the top of teh lifter.
  16. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Hmm, it seems a bit too thick to be the retainer from a lifter. Those are typically made from a very fine spring wire, maybe a bit thinner than a paper clip wire. Based on the diameter of the curve, it looks like it could be a piece of an inner valve spring. The innner valve springs are made from a flattened wire. How hard is that peice? Is it spring steel or something softer?
  17. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    hum...that looks to me like a dime /forums/images/graemlins/rotfl.gif looks like your motor is makin you money /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif..no but really...i think they nailed it...i can think of anything else in there that would possible look like that except for the lifters
  18. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    that is what I was thinking Harry
    the dime reference makes it real small diameter as well, too small to be spring part IMO
    you wouldnt think a crate motor would have teflon valve seals with retainer rings either but it is about that size.
    no one is gonna warrantee it or even look at it unless the motor dies.
    so you have 2 choices rip it down or run it.
    I say run it.
  19. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    The motor is out of warranty...I'd pull the intake and replace the bad lifter and check for other F.O.D. then run it with a measure of confidence.
    Rene
  20. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    IMO that isnt a lifter wire, doesnt look like a wire to me
