help identifying the 56" springs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RodeoRob, Feb 28, 2002.
  1. RodeoRob
    RodeoRob Registered Member
    Sep 16, 2001
    17
    Winston-Salem, NC, USA
    help identifying the 56\" springs
    I'm on the lookout for a pair of rear 56" springs for a project of mine. To help me out, I was wondering if ya'll can explain some of the main differences between those and the 52" springs that will help out in the junkyard.
    1. From what i gather the springs are measured eye to eye... but is that unweighted or weighted (since most trucks are sitting on their springs in the junkyard).
    2. Are the centerpins centered in the 56" springs? i thought they were but someone told me they were offset just like the 52"ers.
    3. How many leaves are available in the 56" variety? 7+1overload? are there more options?
    I know they're found on most 73-87 3/4 tons, but not all. And can also be found on 1/2 tons too.
    I ask because i found a pair on a '74 2wd Custom Deluxe 10 that measured almost 56". when I took them off the truck, they measured closer to the 52". and I also noticed the centerpin was offset when i thought it was centered.
    Any help here?
    -Rob
    <a target="_blank" href=http://www.apptechnc.net/~gorrellrw/rodeo>1995.5 Isuzu Rodeo</a>
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Re: help identifying the 56\" springs
    52" springs have a centered (or close to it) center pin. 56" springs add all the length to the rear half of the spring so the center pin is much closer to the front.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  3. RodeoRob
    Sep 16, 2001
    17
    Oh okay, i guess i had it reversed. So 52" springs have the centered centerpins and 56" ones have the centerpin offset by ~4".
    -Rob
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    You got it close. The 56" springs have the pin 2" off center. So, the pin to front eye is 26", and the pin to rear eye is 30". And the springs are measured along the main leaf, not straight between the eyes.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked, 4" lift, 42" tires
    Some day: massive cutting, shorter wb and rear overhang.
