Help! Installed front axle and.......
Discussion in 'The Garage' started by jwduke, Nov 15, 2003.
  1. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Well I finally installed my 3/4T axle & got things a running. Well I took it out for a test drive, got home & found out the front pinion seal leaking like a sive. I installed a new pinion seal, but upon tightening the nut up I noticed I have around a inch of play! (How tight should the pinion nut be, I don't own a beam type torque wrench, just a digital/clicker type) Is this normal?? Plus the grease in the front axle is now brown. This axle sat for a while, & I thought I cleaned the inside good. Should I drain the grease and try it again or ?????
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Not sure on the torque of that pinion nut, but any play at all is bad!!! You need an inch pound torque wrench too properly set the pinion preload. As far as the fluid (is that what you mean by grease) maybe you could drain and fill it again it shouldn't get dirty that fast. /forums/images/graemlins/thumb.gif
  3. jwduke
    Aug 25, 2001
    721
    The fluid (Grease) is a rust brown color, so I guess i'll drain that & start over. Well guess as far as the end play, i'll have to live with it till I can afford a D60! It doesn't make any noise under power, which I guess is good........
  4. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    you're not driving it with an inch of play I hope /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
  5. jwduke
    Aug 25, 2001
    721
    Don't have much choice........
