HELP!!! installed x-over today, which is the correct arm?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by topless1tonk5, Jun 25, 2002.
  1. topless1tonk5
    topless1tonk5 Registered Member
    Dec 10, 2001
    98
    littleton co.
    i think the arm i found laying around is off a jeep and is too short because it wont put it to the bumpstop on either side. i think it is a ford arm but what year/model? thx--j.c.
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    If you are asking for the Ford arm, get the '78 or '79 F150 arm. /forums/images/icons/wink.gif
  3. topless1tonk5
    Dec 10, 2001
    98
    littleton co.
    i assume 4wd? what is everyone useing to get bump-to-bump?
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, 4x4 arm. That's what I have laying here for my future X-over conversion. I have the Superlift arm. /forums/images/icons/wink.gif
  5. topless1tonk5
    Dec 10, 2001
    98
    littleton co.
    which works better, the factory ford or superlift?
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    The Superlift is a drop pitman arm.
    I would say the Superlift, or any other aftermarket lift kit company, arm would work best as the drop allows it to clear the bottom of the frame better than the stock type arm, which points straight out and may hit the frame.
  7. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    I bought the ORD arm as part of the kit. /forums/images/icons/laugh.gif
  8. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    You will definately want the Superlift or Equal brand 73-79 F150 4x4 Arm. Superlift has this arm listed as part number #1104. Procomp and Skyjacker also sell them.
  9. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I have Tuff Country`s Pitman arm PN. TCI-70203, It came with Stephen`s kit. /forums/images/icons/cool.gif
  10. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Superlift #1104 is a Jeep Wagoneer drop pitman arm which uses the same tie rod as the Chevs. The Ford version uses a SMALLER tie rod, and has to be bored out to accept the Chevy tie rods, as well as modified in the spline area to fit onto the 2WD steering box. I know, I did two crossovers and used the Ford drop arm and the Superlift for a Jeep Wagoneer drop arm. DO NOT GET THE FORD VERSION!!!
  11. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I used ORD tie rod ends, I had NO Problems getting it to work! And it has held up to my Obusive driving habits.
  12. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I'm using an 80's Ford Van pitman. About 3" drop, fits perfectly under the frame rail and it cost me $6 from the u-pull-it. Waxer put me onto those and they work great...
  13. thatK30guy
    Jan 12, 2001
    32,076
    55
    Ken, I looked in my Superlift catalog and they list the Ford F150 pitman arm at part number #1104.
    Then I checked out the Jeep Wagoneer pitman arm part number #1104 to fit the '74-'90 J10$20, Wagoneer and Cherokee.
    Wonder why you are saying NOT to get the Ford arm when they are the same part number between the Ford and Jeep? /forums/images/icons/tongue.gif
  14. topless1tonk5
    Dec 10, 2001
    98
    littleton co.
    got the superlift arm, thx guys
