help installin 8in lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shupach, Sep 30, 2001.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    just need help with tcase and diff angles, and driveshaft. do i need a new driveshaft? Im thinkin one of those high angle driveshafts should solve angle and driveshaft problems? but wats your opinion on this, seeing how im sure that driveshaft will be very expensive.
    phill
  2. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    It wont work! Put it back in the box, and ship it to the address I will P/M to you. LOL! [​IMG]
    You will prob need to drop the Tcase, and pitch the pinion up some. Are these rear springs, or add a leaf and blocks? The blocks will prob have a taper built in to turn the pinion up for you, and the spring packs should have a built in shim.
    If ya can't stop.......Smile as you go under! [​IMG]
  3. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    the high angle driveshaft will help with the TC end of the shaft but not with the pinion end. the high angle shaft was built to help guys with tons of suspension travel i believe. i dont think it is a cure for excessive pinion angle problems.
    i have no driveshaft issues with 10" springs having had the dif cut n turned to put the pinion 6deg high at rest. i have junk springs from superlift so travel hasn't caused me any trouble.
    i would say yes you need new driveshafts
  4. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    Dropping the t-case and raising the pinion angle is about all you can do. Cutting and turning the diff works, or you can use degree shims. I have a 9" suspension lift on my Blazer and I'm using 6 degree shims which work just fine.
    Pedal mashed and KICK'N ASS!
    WFO! Wide [censored]'n OPEN!
  5. shupach
    Dec 28, 2000
    648
    Dallas, TX
    i know this is a dumb question but how do u drop the tcase?
    phill
  6. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> Loosen the transfer case skid plate bolts and put spacers in between and button it back up ......... It's a must do with a lift of any size !
    L8r,
    . Riz . <a target="_blank" href=http://www.geocities.com/rizmonkey>www.geocities.com/rizmonkey</a>
    <font color=purple> BOW CHICKA BOW WOW !
