Help installing ARB in D60?
Discussion in 'The Garage' started by great scott, Dec 22, 2006.
  1. great scott
    great scott 1/2 ton status
    Dec 31, 2002
    333
    Utah
    I all but destroyed my old front D60 housing, but I had another so I chose to swap housings, and while I was at it, install a 4 link. Now that all the 4 link brackets and such are welded to the new housing I set about installing my old gears and ARB locker. This is the part I need help with! The ARB is a very tight fit with no shims instaled, let alone trying to put in the master shim or any other shims. Bottom line is I don't know why I can't fit any shims in. Any ideas?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    You do know that the shims on a D60 are behind the carrier bearings unlike a 10 Bolt, right?
    Just asking since if the shims are already there and you are trying to add more to the outside of the bearing races it will not work
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    134
    ARB's change the position of the shims, they are kinda wierd like that (at least the dana 30 and 44 ones are). They move the shims to the outside of the carrier bearings because the air seal housing thing has to be exactly in the right place and can't move based on shims.
    Back to the original post, as long as you have all the right parts, who cares if you don't use as many shims? Each housing is machined differently, that's why the shims exist in the first place. If you can get a good pattern and backlash out of it you should be good to go. Good luck!
  4. 1977k5
    May 26, 2003
    9,995
    134
    Yeah, I forgot that the ARB's use a different bearing on one side (saw your post on pirate). Glad you figured it out :thumb:
  5. CK5
    May 19, 1999
    21,626
    702
    CO
    http://coloradok5.com/arbinstall.shtml
  6. readymix
    May 30, 2004
    6,706
    26
    Never knew that. Never installed an ARB. Thanks for the info though.
    Way to much $$ for my taste.
  7. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    The ARB should be a little tight, (but not be a royal pain in the butt to get in) the bearings need preload.
    Are you installing a NEW ARB or was the ARB in your old housing?
  8. 1977k5
    May 26, 2003
    9,995
    134
    He found his problem. He installed regular dana 60 bearings on a dana 60 ARB which requires a thinner bearing on one side.
  9. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    And yet another reason not to run an ARB:rolleyes:.
    Ira
  10. DaPlumber
    DaPlumber 1/2 ton status
    Apr 4, 2003
    212
    Holland Oh.
    ARB's 60 and 14ff.. I love mmmm!!!
  11. great scott
    Dec 31, 2002
    333
    Utah
    Yep I totaly forgot about the thin bearing ARB used on the air feed side. I should beable to pick up a thin bearing today. By the way, it seems that Ford used that thin bearing on their D50 TTB. So with any luck I can find it in stock, and finnaly finnish this thing.
