Help installing Best Tlop softop
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Max, Dec 16, 2000.
  1. Max
    Max 1/2 ton status
    Feb 19, 2000
    158
    Durham, NC
    Howdy all,
    If anyone can help me I would really apprecate it. I got a used soft top for my 71 blazer and it didn't come with the windshield mount template. I need to know how far forward/back the body mount snaps go so that I can locate them properly. Please email me directly at alan.baydush@duke.edu if you can help. I can call you as well, if that is easier. Thanks,
    Alan
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Yes buy all means contact the manufacture, they sent me the owners manuel and the templete/cutout.
    Tip, I hope you have a heated garage, they fit much better at 70+
  4. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,951
    247
    Released from Pueblo, told I belong in Southpark
    I did mine without a template, I just split the difference between the rain gutter and the top. I centered the top on the truck and started with the center snap and woked one snap at a time each direction. Worked well for me. Did the same on the tailgate. I would measure but the hardtop is on now.
    Also I would use screws and not rivots to put the snaps on the windshield and tailgate in case you have to replace any. If they strip out over time you can enlarge the screw size. I have replaced one snap in 4 years.
    Definately put it on a hot garage. pay a buddy to crank the heat to like 75 and leave the top spread out for a day or so before putting it on.
    Just remembered mine is a kayline so maybe different.
  5. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    Where do you find a best top for a blazer. I have gone to their web page and have not ever see one there.
  6. AGM73k5
    AGM73k5 1/2 ton status
    1,246
    Portland OREGON
  7. Max
    Max 1/2 ton status
    Feb 19, 2000
    158
    Durham, NC
    Well, thanx all for the help. But I had installed it before I got any responses. We put it in the garage, turned the wood stove and heat up till we hit 80 and started. It went well. We put the snaps just in front of the break where the edge goes down so that they would be fully flat. HAd gotten the top used, so had to get body mount snaps, which came with screws, so that is good and we pre coated them with some silicon to seal the hole up a bit from water. We started at the center and worked our way out. Fits nicely and makes the rig look great. Wish I had had a digicam with me :( Will post picts soon. Thanks again for all the help and responses.
  8. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    any one know where exactly on besttop.com the blazer top is?
    when i go there all i get is j**p tops.
    thanks for the help
    Confederate's w/ K5's!
    '85 K5: BIG BAD AND MEAN
    K5: Because size DOES matter
  9. 1HIHUM
    1HIHUM 1/2 ton status
    Jun 28, 2000
    366
    Fremont, CA
    Hey Confederate, here is a pic of my 72 with a Best top.[​IMG]
  10. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    how much was it?
    does it require drilling in the body?
