HELP!!!Installing Front Glass
Discussion in 'The Garage' started by TONYP, Mar 13, 2003.
  1. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    Ok, I had my glass taken out before I got the truck painted, it came out fine with no cracks...get the truck home and call the guy to come out and put the glass back in. First off the glass they took out now has a crack in it...ok new glass time...they leave and come back with new glass and install it, i come home and check it out and it's cracked all over...call him up and he says his driver would be back out to put another Glass in. They showed up this morning and are still there...hope they get it in.
  2. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Re: Installing Front Glass
    How did things turn out with the paint shop?
  3. Grim-Reaper
    7,385
    Atlanta
  4. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    What if I buy the standard seal without the lock strip?
    Is that better than using a rope in the gasket to pull the window and seal in at the same time. I did it that way a long time ago on a toyota and it worked really slick.
    Brett /forums/images/graemlins/burb.gif /forums/images/graemlins/k5.gif
  5. TONYP
    Aug 13, 2002
    2,116
    so cal
    the paint came out great...but the glass still isn't in right, they have to try with a new gasket...
  6. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    while we are on the topic..how much does it usually cost to have a placee do it? of course my insurance would probobly cover it anyhow..i would like to use one from one of the blazers i got here...but i dunno how to take it out..and i would have to have them put it in..kind of a pain in the butt..or is it easy enough that i could just do it? my neighbor said he had tools to do it with so..but i was just wondering...but i gatta do it quick..cuase its time for a new sticker...
  7. TONYP
    Aug 13, 2002
    2,116
    so cal
    anyone change the front glass on first gen...guys are still trying to install the damn thing... /forums/images/graemlins/1zhelp.gif
  8. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    That must be the problem... Mine is a second gen and the glass on these just pop in and out! Sorry they're having such a problem! You would think they'd done this before????
  9. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    First Gen's SUCK for w/s replacement. I can understand the problems but they should be able to get it in.Aftermarket gaskets are mainly the problem, they don't fit right and they look like poo. If you have the chromes still good luck, I doubt they will get it right. I dispise doing those, and so does everyone else in my shop.
    GOOD LUCK!
  10. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    coulkd you tell me how to switch windows? i want to switch the windshelds from my blazer ot my truck...
  11. TONYP
    Aug 13, 2002
    2,116
    so cal
    you got it...not putting the chrome gasket in as the guy said it was harder to do...they still haven't got it in and there on there second gasket... /forums/images/graemlins/k5.gif
  12. TONYP
    Aug 13, 2002
    2,116
    so cal
    OK...they were here today for another 3-1/2 hours and it's in... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif...
    kinda of unfinished in the top inside corners but if it doesn't pop out by morning then I will take it...
  13. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Did they use the "rope" method for installation? You know put like a 3/8 diameter rope in the groove, to spread it, and slip it in that way?
    When Safe Lite, came out and did mine, they had it in and gone in around 45 minute's. /forums/images/graemlins/grin.gif
  14. TONYP
    Aug 13, 2002
    2,116
    so cal
    yep, they used the rope but must of been a long time since they put a real truck glass in... /forums/images/graemlins/k5.gif
