HELP! is my cam roller or normal lifters
Discussion in 'The Garage' started by camokrawler, Apr 9, 2006.
  1. camokrawler
    camokrawler Registered Member
    Mar 2, 2006
    47
    Central North Carolina
    Broke a bolt on my intake today putting in a thermostat and some moron put the wrong loctite on the bolts so the one bolt i took out actually pulled the threads out with it. so i got pissed and am putting a performer intake and cam in it just to do it RIGHT. heheh. i have an 87 tbi 350 and need to know if its a roller so i can order the right cam. i need to order by midnight so it will be here tuesday. also, any installation/breakin tips.
    thanks
    camokrawler
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    uhm, pull your intake. no way to really tell what you've got under the hood. in the last 20 years, ANYTHING could've been swapped in there. with a broken intake bolt, the truck should be down anyways, just pull it and find out for yourself.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    good point, are you talking about an Edelbrock performer cam? please tell me no...
  4. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    I've got a comp cams extreme 4x4 cam in my jimmy with a performer intake and it seems to be a pretty good setup. Everyone has their own opinions though.
  5. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Be sure to get a cam that is computer friendly.
  6. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    If the intake is off, you can tell by the following.
    1. if there is a metal "Spider" like tray in the middle (you will know if you see it) then it is a roller cam.
    2. if it is just your lifters and pushrods, nothing else, then its a flat tappet.
    87 up truck blocks have provisions from the factory for roller cams, just didnt get the equipment.
  7. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    I've had no problem with mine, but I assume other have had dissimilar experiences.
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    while there are no "problems" with the Edelbrock line of cams, 99% of them are ancient grinds. granted, their $120 pricetag for a cam and lifter set is pretty tempting, add a little more to it, and get a more updated grind. the Comp XE 4x4 series are supposed to be really good.
