Help it's COLD in tahoe!
Discussion in '1992-Present Chevy & GMC models' started by 1STK5, Dec 3, 2002.
  1. 1STK5
    1STK5 Registered Member
    Jan 31, 2002
    24
    AC,NJ
    Help it\'s COLD in tahoe!
    The wifes 95 tahoe is freezing. Heater seems to come on but I can't get the fan to come on. Fuses OK
    Any ideas?
  2. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    Re: Help it\'s COLD in tahoe!
    Not sure, but I think the blower motor is on a relay under the hood.
  3. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    The blower motor relay is behind the glove box. Pull the glove box out and you will see the top of the air box. Theres 3 relays. Make sure it is clicking when you turn the fan on.
    If it is, next pull out the resistor array out of the air box. It's shaped like this <> and it has 2 screws holding it in and a wiring harness plugged into the center of it. It's screwed into the top of the airbox. It holds the resistors that control the speeds of the motor. They are a common thing to have burn out. Usually you will loose everything but high because they don't control high.
    My theory if the fan doesn't work at all would be that it's the relay.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Look up under the dash, below the glove box. That's where the blower motor is located. You'll see 2 wires going to the blower motor. One is power, the other is ground. Check to see if there is power on the power wire when the fan should be on. If there is, then the motor is dead. Changing it is a royal pain in the a$$. If there isn't any power at the blower, then you'll have to start working back through the circuit to find out where the power stops. /forums/images/graemlins/frown.gif
    To change the motor you have to remove the glove box, ECM and the ECM mounting bracket. Then you can remove the sound insulation cover that is over the motor. You'll probably have to loosen the lower part of the dash to get the motor out. The guy that designed that setup needs to be slapped! /forums/images/graemlins/angryfire.gif
  5. 1STK5
    Jan 31, 2002
    24
    AC,NJ
    Thanks to all for your help, at least now I have a starting point.
