HELP! ive got money and dont know what to do!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jonny-K5, Sep 6, 2003.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    so here is the deal, ive got some insurance settlement money, and my rear 10 bolt is clunking when i put it in gear so i need to have some work done to it. so what should i do? my options are:
    1)re-gear both 10 bolts to either 4.10 or 4.56
    2)install the 4.10 14bff that i have in the back yard (needs new perches, spring mounts,spring plates and u-bolts) and re gear the front to match, machine the rear hubs and run 6 to 8 adapters to keep my rims and tires.
    i cant decide which way to go, everyone always says dont spend any money on 10bolts, but the 14bff seems overkill for me now. im running 33's. maybe 35's in the distant future but i doubt it, i dont want to lift any higher and i dont want to cut the fenders, the truck is too cherry. if i do go with the 14b then im stuck with the 4.10 and im not sure if i'd rather have 4.56.i've looked at the gear tables alot and still cant decide. i have a 700r4 and like to cruise around 70-75.
    what would you guys do? sorry for the long post!
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Go with the 14 bolt full floater, swap the front over to 8 lug, and get yourself some 8 lug 15" rims.
  3. stump_puller
    stump_puller 1/2 ton status
    Apr 5, 2002
    871
    135
    Corbin, Kentucky
    /forums/images/graemlins/thinking.gif I agree that would the best. /forums/images/graemlins/thumb.gif
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    #2.
    Better to have overkill then underkill. I spent $1000 to rebuild my 10 bolt rear. I only spent $900 when I did my 14bff swap.
    There was a little extra money for the rims and the front conversion, but you don't have to with the adapter for the 14bff.
  5. bigtruck87
    bigtruck87 Registered Member
    Mar 19, 2003
    33
    Treton, NJ
    ummmmmmm......don't know what to do with your money huh, well you could always give it to me.
  6. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    i do know i want to spend it on myself!
  7. great scott
    great scott 1/2 ton status
    Dec 31, 2002
    333
    Utah
    I am a beleiver that any time you can go big, you should go big! It never hurts to have to much beef.
  8. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    ff14b all the way, if you have to use the 10b up front for now, thats ok... its not really that bad of an axle. In the rear though, it makes much more sense to go with the ff14b.
    j
  9. bigtruck87
    Mar 19, 2003
    33
    Treton, NJ
    ok well if you have to spend it on yourself and not me. its always better to go overkill rather then too small.
  10. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
  11. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    You should invest it in a retirement fund so you can retire earlier.
  12. mrbill
    mrbill 1/2 ton status
    Jul 1, 2003
    170
    Sugar City, Idaho
    Right on - the $$'s I put away as in my 20's has let me retire at 47. /forums/images/graemlins/pimp1.gif
