HELP LEAF OUT OF PLACE!! PICS
Discussion in 'The Garage' started by LIFSVR7, May 12, 2003.
  1. LIFSVR7
    LIFSVR7 Registered Member
    Jan 16, 2003
    51
    NW Indiana
    I just seen today that one of my leafs is out of place on the driver's rear... I have no clue how or why, could have somthing ot do with when I got stuck in the creek bottom and got pulled out... anyone know how I can get it in?? /forums/images/graemlins/1zhelp.gifPLEASE
    PICS HERE... [image]http://community.webshots.com/user/lifsvr7[/image]
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    nice work.
    remove the ubolts and see if the centerbolt is broken
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    WOW, mine helicoptered too but nothing like that!!
  4. Grim-Reaper
    7,385
    Atlanta
    Quality!
    Uhh my bet is your u-bolts are loose. That or you have s shim that got spit out. It also wouldn't surprise me if your center pin is bottoming out on the axle tube. You might need to grind it down some. Your u-bolts should be straight up and down not off at an angle like that. 1020lbft of torqe on thos bolts as I recall with the weight of the vehicle on the axle to compress the spring.
  5. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Ya grim reapers right gotta tighten them with the the weight on the springs, but straichten up the u bolts first.
  6. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Where would I find a torque wrench that goes that high? /forums/images/graemlins/rotfl.gif
  7. LIFSVR7
    Jan 16, 2003
    51
    NW Indiana
    Ok, so how in the hell do I get in back in line??? I know I have to straighten out the ubolts.. and retorque them... I also see where it has slid on the axle... so Do I just loosen them and line it back up then retorque em??? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/usaflag.gif
  8. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    take the wheel off, take the weight off the axle, then let the weight rest on the frame after the axle is suspended loosen up the U-bolts, check everything out, if everything is ok and you dont have to call rough country for new parts, grab a bud, no not a beer, a buddy who is willing to help, then get the leafts close together, then when they are hitting the wear pads, hammer, pry, twist, hit, yell, do anything you have to do to get them back in line again, my over load spring is out of wack on the bottom, on the drivers side, i tryed hitting it with a hammmer with the weight on the vehicle but it started moveing the shim on the bottom and wouldnt move very far from there. anywho, yes torque them U-bolts to 120-140 ft\lbs, But to be safe id call rough country and see what they have to say. good luck. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  9. LIFSVR7
    Jan 16, 2003
    51
    NW Indiana
    Well, it was not as bad as I made it to seem... I did it today.. thanks everyone for their help... I didn't have a torque wrench so I just tightened the hell out of it with a breaker bar... /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
