Help locating VSS source
Discussion in 'The Injection Section' started by Mastiff, Nov 25, 2006.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I think my 83 K5 (with factory cruise) has a VSS signal coming out someplace, going to the cruise box. I removed all the cruise stuff under the hood. Can someone help me identify the VSS wire? I'm assuming it's what the 7747 ECM wants.
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Think it runs off vacuum, not a VSS. But that would be on the back of the speedo...
  3. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    Yep, VSS is located on the back of the speedometer. You'll want to make use of the brown wire coming off of the connector for your ECM.
    And b454rat -- In 83 cruise control was switched from a vaccum servo style to an electronic style that uses a speed sensor just like modern vehicles :)
  4. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    You sure about the brown wire? I was digging through the diagrams in my shop manual, and it looks like there is supposed to be a little box attached to the back of the speedo, then ground, power and a yellow wire with the VSS signal. I haven't dug around in the truck yet to check this stuff out.
  5. Russell
    Jun 23, 2000
    7,923
    333
    Might be yellow, mine was brown, but mine came from a car, not a truck. Either way, the color of the signal wire doesn't matter, just don't hook the pink / black (12V), or black / white (ground) to the ECM's VSS pin :)
