HELP! LT1 motor in a 91' K5?
Discussion in 'The Garage' started by CCRider, Jul 4, 2002.
  1. CCRider
    CCRider 1/2 ton status
    Jul 8, 2001
    314
    Charlotte North Carolina
    HELP! LT1 motor in a 91\' K5?
    Can get a pretty good deal locally on a 96' LT1 motor , and was wondering if anyone has used this motor in a heavy truck such as ours , how the powerband works offroad/street , mileage, install problems , etc. will probably switch to speed density ala 1994, instead of the MAF. 4L60e trans. Any info would be most helpful!!! Thanks CC
  2. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Re: LT1 motor in a 91\' K5?
    Sounds good for the mud and sand. Wouldn't want one in the rocks though.
  3. CCRider
    Jul 8, 2001
    314
    why not? Explain please. CC
  4. CCRider
    Jul 8, 2001
    314
    Re: HELP! LT1 motor in a 91\' K5?
    C'mon guys , someone must have some knowledge on this stuff!!! CC
  5. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    Mud and Sand need a bunch of speed and wheelspin(Horsepower)
    Rockcrawling is more off idle torque and mid range torque.
    The LT-1 in that car is mostly for hp (correct me if i'm wrong). Therefore if you were rockcrawling you would have to keep the motor tached up to do obstacles where a motor geared towards torque would crawl up. Hope this helps.
    James
  6. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    That motor is wonderful for both HP and torque..........the only downside is the location of the 'distributor'.........it is mounted down by the crankshaft on the front of the motor.........right in the line of fire of water/mud. Some guys say you can somewhat waterproof the 'Opti Spark' but I'm not sold.......... /forums/images/icons/tongue.gif
  7. trailblazer87
    Jun 11, 2002
    707
    Madera, CA
    You can't truly water proof it, all distributors have to have a vent. They build up gases inside tem and if they aren't vented they will pop, you can plug the vents for a short time but not more than a few hours.
  8. 88streetblaze
    88streetblaze 1/2 ton status
    Jun 27, 2001
    314
    middle of sticks, oklahoma
    i'm to lazy to type it all out again so check this old post
    lt-1
    i've also got pics
    web page
    i would do it again
  9. BurbinOR
    5,829
    Oregon
    Yeah, I know. That's why I said I'm not sold.........but some guys are venting them with hoses upwards and away and making them work *to some degree*. I still have my doubts about a submersion tho............ /forums/images/icons/blush.gif
