HELP ME!--added lift/frt d-shaft issues
Discussion in 'The Garage' started by Stephen Lee, Jan 28, 2006.
  1. Stephen Lee
    Stephen Lee Registered Member
    Nov 21, 2005
    9
    Michigan
    I had a 78 k5/ d44/ 12B/3.08/ 350/ 465/ 205/ 4"susp/ 2" body/ 4X4
    Now its a 78/ k5/ d44HD/ 14FF/4.11/ 454/ 465/ 205/ 6" susp/ 2" body/ 4X2
    the front shackles are 2.5" longer than stock, had 4 degree shims.
    I went to 6 degree shims and dropped the tranny an inch.
    BUT THE DOUBLE CARDAN STILL BINDS!
    WTF?
    :mad:
    WOULD LIKE TO GO TO THE GRAVEL PIT TOMORROW:crazy:
  2. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    Lots of good info out there on this topic.... some things to consider; dropping your tranny/case puts your front driveshaft at a steeper angle because it's pointing the flange further up. With 2.5" longer than stock shackles, your pinion is still probably way to far down even with the shims. ( hard to tell without seeing it) Have you ground out the bumps in the cv portion of your driveshaft? I'd look at all of these things.
  3. Stephen Lee
    Nov 21, 2005
    9
    Michigan
    thought about grinding cv but how much can I take off around u-joint caps?
    I was wondering if it hurt or helped to drop the trans. with everything pivoting at the motor mounts...
    think 6" spring as oppossed to the shackles would do it? $$$$:doah:
  4. Stephen Lee
    Nov 21, 2005
    9
    Michigan
    how much lift does your 77 have to clear those meats?
    how did you lift it?
    and how did you correct driveline issues?
    Ton o ?'s 4 u
    were do I find all of said info?
