Help me BABY JESUS
Discussion in 'The Garage' started by mollyman, Oct 23, 2006.
  1. mollyman
    mollyman 1/2 ton status
    Aug 18, 2006
    280
    west virginia
    Could somebody help me (before I go insane)???? I've got a 10blt and all I want to do is change the rotors. I got the hubs out, I got the snap ring and washer out, I got the spindle nut out (the one that takes the special socket), now the hub/rotor should come off rite????????? I can't get them to budge! They do have rust on them could they just be all rusted up or what because I beat the hell out of the rotor from behing with a mini sledge and that didn't do anything. When I look in at where the hub used to be I can a silver "thing" it is round with four evenly spaced teeth sticking out and small holes evenly spaced around it??? Any body got any ideas or did I do something wrong.:mad:
  2. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
    That part that you see with the evenly spaced holes in it is a locking washer it needs to be removed then you will see that there is another spindle nut behind it that has to come out then you can remove the hub & rotor assembly :D
  3. mollyman
    Aug 18, 2006
    280
    west virginia
    The locking washer does it pull out or does it get screwed out?? And the secound spindle nut does it take the same special socket or do I need a different one??? Thanks for all the info
    P.S. I was almost hoping something was wrong so I could just buy a whole new front axle assembly but I will keep going I guess!!!!
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    it just slides straight out. If you look close there is a groove about half an inch wide in the spindle, and the washer has a little.....fang that slides in that groove. May need a pair of needle nose to grab it, probably stuck to the inner nut by the grease.
  5. k30bb468
    Oct 2, 2004
    955
    NW Pennsylvania
    It slides out like k20 said & yes the second nut uses the same socket.
  6. mollyman
    Aug 18, 2006
    280
    west virginia
    Thanks for the help guys!! I will give it a try.
    P.S. does anybody know the name and address of the guy that designed it so I can go give him a kick in the ass, it sure would make me feel better!
  7. diesel4me
    Jul 24, 2003
    17,546
    937
    Massachussetts
    me first!..
    If I could face the guys responsible for designing many of the retarted setups on vehicles I've had to repair over the years,I'd kick them squarely in the NUTS!...and make THEM fix it!..:p: ..then maybe they'ed start desinging vehicles that can actually BE fixed,without having to just about pull the motor to put spark plugs in,or tear the entire dash out from one side to the other,just to install a 20 dollar heater core!..:mad:
  8. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Actually, that design is pretty clever. Not bending of tabs down in a deep, dark hole. No adjuster nuts that back off frequently and for no appearent reason. No tiny parts to get lost in the dirt.
  9. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Yeah...that design seems like a major pita when you first start messing with it. Once you do it once or twice its cake. I can tear it down and take the axle shaft off of one side in probably about 10-15 minutes. Not too bad really.
    -Harrison
