Help Me Buy Gears!
Discussion in 'The Garage' started by fireplug, Jan 3, 2006.
  1. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    I need to order gears for my D44 and 14bff. First what is the best brand? Second with a Detroit in the rear and Electrac in the front are there any other considerations? What about thick cut? Thanks guys!
  2. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    so long as its not genuine gear, you'll be fine. The science of gear-making has been figured out for a long time. Any of the other major manufacturers will be fine. Yukon is usually the cheapest.
    Not 100% what you mean by "other considerations"....
    "thick" gears are what you need when you are putting gears into the type of axle that has two different types of carriers. This is common in an axle like the ff14b. There is one carrier for gears up to 4.10... and a different one for 4.56+ gears. If you have 4.10s now... and want 5.13s without switching carriers... you order "thick" gears. All of this is covered in other posts... do a search of "thick gears" and you should find all the info you need.
    j
  3. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    i ran a pool one time a few months ago. best bang for the buck was yukon gears.
  4. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Here's where I found my best price on our D44 4.56 yukon gears.
