help me decided, .030 or .060 over?
Discussion in 'The Garage' started by big83chevy4x4, Feb 23, 2007.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i need to bore my 454.
    should i bore it .030 over or go .060 over?
    also the pistons im getting come with either a 1/16" ring or a 5/64" ring.
    should i go with a thinner ring or thicker ring. what are the pros and cons of both.
    im ordering them in a few hours, help me decide.
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,991
    130
    If your block is in good enough shape that you only need to bore it .030", just do that. The more you overbore an engine the weaker it gets and the more potential overheating problems you can have.
  3. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    If you go .060" then you have no rebuilds left in that block, with that being said bore it .030". The thicker ring set would be best for longevity reasons, the thinner ring set would be slightly better from a performance stand point.
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The only reason you need to bore it is to clean up the cylinder walls from any scratches/gouges it got from wear and tear. With that said you should bore it the minimum amount needed to get rid of the wear.
  5. longbedder
    longbedder 1/2 ton status Premium Member
    Oct 26, 2005
    4,193
    356
    Ridgecrest, CA
    .030" over
    get it torque plate honed
    Thick rings (assuming this is an offroad/dd mo-chine)
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ok, i ordered the .030 over 5/64" rings pistons. i was leaning toward the .030 1/16" pisons, but id rather have the longetivity.
    thanks
  7. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    It depends, some of those blocks had some seriously beefy cylinders, and can go more than 0.100 over, but you'd need to have it UT checked first.
  8. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,029
    1,347
    Kzoo, Mi
    Ditto that, rumors abound about going .125, but again Ultrasound testing should be done first.
  9. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    You are about half correct. The early 70's 454 did had some with thick cylinder walls but all of the later blocks are then and .060" they start having heating issues. Most of the early 454's have been long gone to the drag racer and just about every 454 people find today are the later blocks from the late 70's on which are thin.
    The only way to tell for sure though is to have the block sonic tested as you've said.
  10. Bow-Tie-Boy
    Bow-Tie-Boy Registered Member
    Feb 14, 2005
    71
    Ft. Hood, Texas
    X2.
  11. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    x3.
  12. 76zimmer
    Nov 14, 2005
    23,029
    1,347
    Kzoo, Mi
    = 6
