Help me decypher the ring gear numbers.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rugger03, Jul 17, 2002.
  1. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    I pulled the cover on my 14bolt the other day i thought it had 4.10's but now im not sure. the only markings on the ring gear are the letter "f" and then about 180 degrees on the other side 2Gm 39992485 11 41 9 77. 4.56? It came out of a 78/79 K20. thanks rugger
  2. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    we'll if the 41 and 11 are correct then you have a set of 3.73's
    To be for sure you need to count the teeth on the ring gear and the pinion and devide them.
    41(ring gear)/11(pinion)=3.727
  3. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    LakeRat hs it right...the 11 and 41 are the number of teeth on ring and pinion gears. the 9 and 77 mean mean it was manufactured in September of 1977. /forums/images/icons/smile.gif
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    count the teeth to be 100%
