Help me diagnose this noise
Discussion in 'The Garage' started by djohnsn, Feb 25, 2004.
  1. djohnsn
    djohnsn 1/2 ton status
    327
    Plano, Texas
    Clicking sound at slow speeds
    Above 30 mph becomes a roar (sounds very similar to revving the engine)
    Does not vary with engine speed
    Only happens under load (I can put it in neutral and the noise disappears)
    I suspected a transmission problem at first, but my tach does not show the engine revving more than usual to indicate a slipping transmission (th350). Could it be U-joints or rear end? Any ideas would be appreciated.
  2. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    ID guess rear end, but thats just a guess, its kind of hard to diagnose noises without hearing them, Id definatley check your u joints though.
  3. rodriscoll
    rodriscoll Registered Member
    Feb 7, 2003
    18
    Townsend, MA
    I think I have the same problem started out as clicking now sounds like valve train tapping but it is not I think it is the transfer case chain I will be checking into it this weekend.
  4. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    I'm big on narrowing down the problem as much as possible. If it were me, I would pull the rear driveshaft, put it in 4wd and drive it up past 30 MPH. That will tell you if it's your rear axle/driveshaft (based on your statement about load).
    (Also based on that statement) I'm guessing it does not happen at idle?
    If your u-joints are shot, they could be clicking when the shaft flips and the load changes on it.
  5. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    does the clicking noise match your tire rotation? you may have a some bad teeth on your ring gear.
  6. djohnsn
    327
    Plano, Texas
    I would pull the rear driveshaft but since I don't have a usable front driveshaft right now, that probably would not do me much good.
    The noise does not happen at idle.
    I am going to try to make time to replace u-joints this weekend (I am sure that it will not hurt to have new u-joints even if it turns out to be a different problem).
    Thanks for the suggestions.
