Help me find a post, please!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazen91, Apr 13, 2001.
  1. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Someone made a post asking how to change a d60 from duelly to standard. I did a search and could not find it. PLEASE HELP!!!
    <A target="_blank" HREF=http://www.blazen91.coloradok5.com>http://www.blazen91.coloradok5.com</A>
    Protect the land FOR the people
    Not FROM the people
  2. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    I found this...I'll keep looking too...
    <A target="_blank" HREF=http://www.coloradok5.com/forums/showflat.pl?Cat=&Board=blazer4x4&Number=108373&page=&view=&sb=&vc=1>http://www.coloradok5.com/forums/showflat.pl?Cat=&Board=blazer4x4&Number=108373&page=&view=&sb=&vc=1</A>
  3. bigblue
    Dec 6, 2000
    658
    southern california
    I found these posts too...
    "Re: dana 60 dually
    From what I've seen, the dually ones are the same as the regular ones but with wheel adapters on them. I'm pretty sure they unbolt from the hub. Dynatrac will sell you the parts to convert it, but everything they make is $$$$$$$$$$$$$. It is possible to swap on non-dually hubs and rotors if you can find them.
    Shawn
    (old hand)
    12/05/00 08:38 PM
    Re: dana 60 dually
    I've had many questions about the dually 60 and converting it to single wheel so I called Dynatrac and Boyce to get the scoop. You need to replace the entire hub assembly. This is the large heavy part that the hubs, rotor go on to and the bearings go inside the inner part. The rotors are the same but the dealer wants to sell you both hub and rotor (hub/rotor assembly) for $500 each. Dynatrac will sell the assembly for $279 each and Boyce will do an exchange for for the dually hubs for $200 each. I think Boyce is more than dynatrac if you don't have any hub assem. to trade. Brakes and locking hubs (Warn) are the same for either. I'm not sure what the width is though.
    Shawn
    87 K5
    few mods
  4. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Thanks buddy. After we do your axle, you can help me swap in the d60 to Nicole's Blazer. See you then.
    Not FROM the people
  5. bigblue
    Dec 6, 2000
    658
    southern california
    You got it !
