Help me get my Tranny out...Please!!
Discussion in 'The Garage' started by SUPER'BURB, Aug 26, 2005.
  1. SUPER'BURB
    SUPER'BURB 1/2 ton status
    Jan 9, 2005
    929
    Mountain House, Ca.
    I have a '73 Burb. with a 350 and TH350 tranny. I have all the bolts out of the transmition, both against the motor and transfer case. Why won't my tranny come out? I have the motor blocked up so it stays in place...but I can still hang from the tranny with no movement. Please help, I need to finish this soon!
    Thank You
  2. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    Did you unbolt the torque converter from the flexplate?
  3. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Drop your bell housing pan. That is it most likly.
    Adam
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    If the tranny has been on for a long time you can get some corrosion between the steel locating pins and the aluminum case. They sometimes stick pretty good use a small pry bar between the torque converter and flywheel and wiggle it and it should slid off of the pins.
    Ira
  5. SUPER'BURB
    Jan 9, 2005
    929
    Mountain House, Ca.
    My Tq. Converter is already unbolted and spinning freely
  6. SUPER'BURB
    Jan 9, 2005
    929
    Mountain House, Ca.
    What is a bell housing pan? do you mean the dust cover or the tranny pan?
  7. SUPER'BURB
    Jan 9, 2005
    929
    Mountain House, Ca.
    Do you mean pins between the block and tranny?
    Thanks for the responses please keep it up. :bow:
  8. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    The dust cover. BUt I guess you are on top of that.
    Adam
  9. sandawgk5
    Oct 28, 2003
    6,881
    Yes I was reffering to the pins between the trans and engine block that help locate the tranny. So did you get it loose?
    Ira
  10. 4wheelin4Jesus
    4wheelin4Jesus 1/2 ton status
    Mar 20, 2005
    149
    north carolina
    I just did this last week for the second time. It sounds like all the bolts are loose. All cables, and Dip stick have been removed? How about the shifter linkage? If all this is done, It sounds like what is mentioned before. The shaft connecting the engine to the tranny that the torque converter is on is causing the problem. Youve got to just get mean with the thing. But be careful too. Youve got to wiggle it up and down, and left and right at the same time as you are pushing it to the rear of the vehicle.
    Good luck
  11. SUPER'BURB
    Jan 9, 2005
    929
    Mountain House, Ca.
    :o Obviously I am not the sharpest tool in the box :doah: :o ... This being the first time I have taken the tranny out of this type of rig I was unaware (read not thinking) about removing the cross member and just dropping it all down, t-case and all.
    Once I did that it came right out :woot: .
    Thanks for all your help, I guess we'll see how it goes :bow: .
