Help me ID intake manifold
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazer79, Mar 6, 2001.
  1. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Does anybody know what engine (possibly Pontiac) does an intake manifold with the following casting numbers is from?
    411990
    D6CE
    Thanks.
    <font color=blue>//////
    <A target="_blank" HREF=http://blazer79.coloradok5.com>http://blazer79.coloradok5.com</A>
    </font color=blue>[​IMG]
  2. dyeager535
    26,979
    Well, Pontiac should be pretty easy...its open underneath the runners if I remember my pontiacs right. Olds big block nor small block will have a hole for the distributor, but Chevy will of course. Don't think Buicks nor Pontiac had the distributor hole either....other easy Olds ID is the choke will be the hot air style, but no coil on the intake....there will be two small "fittings" that choke tubes fit into, passenger side, and they are held in by a small plate with two bolts.
    Dorian
