Help me ID some stuff.
Discussion in 'The Garage' started by broncoman6524, May 22, 2006.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    Cleaned the backyard due to my sis gettin a horse.
    All this came from a 51 suburban that was CONVERTED to 4wd. So its all Gm i think.:confused: :D
    1. front axle.
    2. Rear axle, Eaton 14b possibly?
    3. Manual tranny, 4spd granny gear
    4. T-case
    Any help would be appreciated, the axles have 4.10s in them and im trying to figure out if it would be cheaper to clean them up and go through them. Or just regear my 10b's
    thnx chris
  2. slyguy_22
    slyguy_22 1/2 ton status GMOTM Winner
    Dec 13, 2004
    789
    Lancaster, PA
    front axle kinda looks like my dana 44, but wheres the brakes? best thing i can suggest is look for the id numbers on them (should be stamped on them) and cant remeber the site but u can type in the numbers and get what they are. they look kinda ruff. what are u gona put them on?
  3. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    SM 420 for the tranny ?
  4. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    the brakes are in the shop. apparently my dad pulled them? I dunno i was thinking about puttin the axles under my blazer after i went throught them. I dunno bout the tranny and T-case.
  5. austink5
    austink5 Registered Member
    Mar 30, 2006
    8
    austin, Tx
    the sm420 has almost a 7 to 1 first gear and is i believe the lowest geared stock tranny...good for a crawlin rig.
    Www.novak-adapt.com has good info on that tranny and a chart to properly identify
    Mat
  6. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    looks like the ball and cup front knuckles, not very highly desired
  7. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    That looks like old Napco stuff to me. Front axle is Napco which is built from the old GM corporate axles (like the rear axle you have there). The rear is an old corporate half ton unit, it is a cousin of the "Eaton" axles (but smaller). That is an HO33, the half ton axle that was used prior to the introduction of the 12 bolt. The transfer case looks like what was used with the Napco conversions also. It should have a Napco tag on it.
  8. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    I've never seen a D44 that has a drop out center section before :rolleyes:
    that is a NAPCO axle. the rear is a semifloating Eaton. I would suggest trying to sell them to the restoring crowd, and steer clear of using them in your rig.
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
  10. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    napco = big money to colectors and resto guys.
  11. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Definately the SM420
