Help me identify these Axles.
Discussion in 'The Garage' started by Uzaree, Sep 15, 2006.
  1. Uzaree
    Uzaree Registered Member
    Jan 5, 2006
    18
    Mississippi
    Hey guys, I just ran into a guy that has a 86-87 Chevy Suburban that has a 6 lug's wheels and wanted to know what rear ends this thing most likely has. Anyone know? It has a 350 with a 700R4, he's not sure of the T-case.
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    10 bolts front and rear. Case is most likely a 208, possible a 241, depends on year.
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    87 is a 208 it is the same as I have.
    Ira
  4. Uzaree
    Jan 5, 2006
    18
    Mississippi
    Thanks, so I should probably stay away from these then?
  5. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,726
    108
    earth
    The way I read this is that you want to know what the rear gears are? NOT the transfer case.
    The rear on mine is 3:08s look in the glove box and see what the codes are.
    GM8 rear axle 2:56
    GQ1 rear axle base ratio
    GT4 rear axle 3:73
    GT5 rear axle 4:10
    GU4 rear axle 3:08
    GU6 rear axle 3:42
    G80 axle rear limited slip
    These RPOs are from OEM 1987 Light Duty Truck unit repair manual ST-333-87 need any others just ask.
  6. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    they are not worth anything. Tie a rope to them cause they are boat anchors.
