Help me out here!
Discussion in 'The Garage' started by santana, Mar 23, 2004.
  1. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    What are symptoms of a steering gear going bad? When I turn the wheel slowly while parked I feel the steering wheel skip and pop. I checked around and everything looks good down there plus since I went wheeling a couple of weeks ago the steering wheel isn't straight while driving straight. /forums/images/graemlins/1zhelp.gif no leaks, plenty fluid in reservoir, new pump. /forums/images/graemlins/dunno.gif
  2. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Check the frame for cracks where the steering gear bolts on. /forums/images/graemlins/dunno.gif
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I feel the steering wheel skip and pop...the steering wheel isn't straight while driving straight
    Unless your draglink adjusting sleeve is not tightened and it's skipping threads, you've got a bad steering box.
    Check the draglink issue first, but if it's the steering box, I'd keep the truck off the road until you fix/replace the steering box. The possibility of losing steering is very dangerous to you and others.
  4. santana
    Jan 11, 2003
    1,483
    Mesa Arizona
    no cracks to frame, and the draglink is nice and tight so that would prolly leave me with a bad box huh? /forums/images/graemlins/dunno.gif /forums/images/graemlins/doah.gif
  5. santana
    Jan 11, 2003
    1,483
    Mesa Arizona
    Good point, thanks! /forums/images/graemlins/thumb.gif
  6. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Also check your locating pins on the springs. If they are worn it can allow the spring plates to wander and make poppin sounds. Good luck to y'all in the future.
    Allan
  7. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    The larger bolt in the top can be used to adjust the gear back lash (sorta). It is not a perminent fix, and might not work at all if the play is real bad. Get a new box either way. While you are there put on a frame brace if you plan on wheeling it often (4 wheelers supply <33st & washington> has them in stock).
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    All these replies sound like possible causes. Mine was the front springs. Just didn't feel right and my whole front end made real bad noises, worst when backing up with wheel cranked. Went away after my lift. I was spraying lithium on it every week to fix it, so leaves would move better on each other. Just a thought /forums/images/graemlins/k5.gif
