Help me PC shop, pleeeeeease! Down to two choices.
Discussion in 'The Lounge' started by TSGB, Apr 28, 2006.
  1. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    I'm looking at two pcs, and one advertises the ram running at 400 mhz, as opposed to the 533 that I usually see.
    Is this going to be an issue for upgrading later? Is there a big difference?
  2. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Ooh, and can you burn cd's with a dvd burner?
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Yes:D
  4. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    One PC is probably using DDR/400 RAM and the other is probably using DDR2/533 RAM. IMO there isn't much difference....a bit of speed but that is it. One thing to remember though, is that DDR2 is the newer standard that most PCs are going to. That being said, the PC that I built in February uses DDR400. So, that technology is still viable.
    What are the specs of each PC?
  5. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    This is the one I'm leaning toward, since I don't have a tv.
    Operating SystemMicrosoft(R) Windows(R) XP Media Center Edition edit ProcessorIntel(R) Pentium(R) 4 524 w/HT Technology, 3.0GHz edit Memory1GB DDR2-533MHz dual channel SDRAM (2x512) edit Hard Drive250GB 7200 rpm SATA Hard Drive edit Primary CD/DVD DriveSAVE $30! LightScribe 16X DVD+/-R/RW drive edit Front Productivity Ports9-in-1 memory card reader, 2 USB 2.0, 1 IEEE 1394 edit Networking802.11 b/g Wireless LAN PCI Card edit TV & Entertainment ExperienceSingle NTSC TV Tuner with PVR and FM Tuner edit Graphics Card256MB DDR ATI Radeon X1300 Pro, TV-Out and DVI edit Sound CardIntegrated 7.1 Capable Intel(R) High Def. Audio edit Keyboard and MouseHP Multimedia Keyboard, HP Optical Mouse edit Productivity SoftwareMicrosoft(R) Works 8.0/Money 2006/MSN Encarta Plus edit [​IMG]your additional options:[​IMG]Click "edit" to modify. NOTE: These items are in stock and will ship immediately.[​IMG]Featured PrintersHP PSC 1510 All-in-One edit Printer cablesHP USB 2.0 Printer Cable a-b, 6' (2 m) edit MonitorsHP 19" LCD Flat-Panel Monitor edit High End Media Center AccessoriesHP Media Center Remote Control edit
  6. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
  7. CustomChevy
    CustomChevy 1/2 ton status
    Jun 29, 2005
    4,328
    Kitchener, Ontario, Canada
    FYI ... you will NOT like media center edition AT ALL!
    and that second pc has a WAY better processor.
  8. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    What's so bad aboot media center?
  9. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
