Help me please!!! Bleeding clutch system!!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KrebsATM02, Mar 4, 2003.
  1. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    Here is my situation, i'm putting a sm-465 in my blazer and decided to go hydraulic. The only problem is i couldn't find a bell housing, so i made my own bracket to hold the slave. The bracket is plenty strong and it mounts so that when the slave is pushed all the way in the fork is on the 16 little prongs on the pressure plate. Also, i made the bracket inside the truck on the pedal only to move an 1.5", because that is the stroke length on the master cylinder. I'm also using a hydraulic line, with an 1/8 inch ID. When i bleed, all i do is keep getting air. I took the slave off and held it down thinking air could get trapped somewhere. What is my problem???? I need this fixed now, i still have to swap a dana 60 in before saturday morning when i leave on a 14 hour trip to las cruces for spring break. Help me please!!!!! /forums/images/graemlins/confused.gif
  2. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I do NOT envy you. I recently had experience bleeding the clutch on a early 90's 1ton. It straight up sucked. Everything was brand new. We tried everything from a vacuum pump to holding the slave cylinder at 45 degrees. Bottom line is to bench bleed everything you can and have a buddy help by pressing the clutch pedal while you work the bleeder screw.
  3. KrebsATM02
    Mar 21, 2000
    553
    Help please, I'm desperate!!! /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/confused.gif
  4. Langosta39
    Langosta39 1/2 ton status
    Nov 8, 2002
    156
    Moscow, Idaho
    go read this months Peterson's 4 wheel offroad magazine, they bleed a toyota hydro clutch and tell you how to do it
    andy
  5. KrebsATM02
    Mar 21, 2000
    553
    You couldn't give me the low down real quick? I know how to do it, it's just not working for some reason!
  6. KrebsATM02
    Mar 21, 2000
    553
    anyone else?
