Help me spend some $$ on my K5
Discussion in 'The Garage' started by la_blazer82, Mar 28, 2005.
  1. la_blazer82
    la_blazer82 1/2 ton status
    Apr 12, 2004
    148
    SoCal
    I just bought some stuff for the K5, including:
    4.56 gears for the 14bff (Paid $205.99)
    Detroit Locker (rear) (Paid $383.99)
    Install kit (Paid $36)
    Mile Marker Premium Hubs (Paid $65)
    Rancho 9000x (Paid $272)
    I have roughly another $1k to spend, but this includes money that will go towards the gearing/locker install. I figure I'll have $500-650 left over. What should I get:
    1. New rear d-shaft (recently installed ORD flip + zero rate in the rear; dropped down the t-case to help d-shaft vibes). Probably would go with HAD or Tom Woods
    2. 14bff disc brake conversion
    3. rock sliders
    4. rear bumber w/tire carrier
    5. cross-over steering (front D44 - but don't have flat knuckles or 2WD steering box)
    Question: 1. Does anyone have part # to Detroit? The Truetrach box I had has a check mark next to "NoSpin", and the locker doesn't look like some of the pics I've seen of the Detroit Locker. I think the part # I received is S225-10
    2. The hubs I received are for a 1/2 ton K5, but the front D44 I have is from out of a 77 K20. The Part # for that year 3/4 K20 is different. Should the be the part # for '77 K20? (Just want to make sure)
  2. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    I would get the rear disks, HAD shaft and a SYE. That way the rear end would be done.
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    I agree with spearchucker. Actually, call Jesse at HAD and see what the conversion and a rear d-shaft costs. More than likely it will probably be more than what you'll have left, but that would be my next route.
    Also, I would take the t-case drop out too. The sslip yoke eliminator will help with angle and maybe even go with a CV rear shaft depending on your lift size.
    Hubs should be the same for a 10 bolt or D44 in either the 1/2 ton or 3/4 ton versions. That is unless you have the external hbs, but I believe they stopped in 74.... That would be the only other D44 hub part# I could think of.
  4. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    X-over Steering would be my choice....
  5. la_blazer82
    Apr 12, 2004
    148
    SoCal
    thanks for the replies. I know the HAD shafts are $$$, but well worth it. Only have a ORD flip + Zero rate in the rear, so I would be putting the t-case in stock position after a new shaft
  6. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    take that 650 and put it in the piggy bank, save a lil more and get a doubler?
  7. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Diff protectors/heavy duty tie rod/steering box brace?/Air compressor/spare parts...........
  8. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    My choice would be crossover and sliders. A beefy tierod and some diff cover protection would be nice too. A HAD shaft would be nice to have but if your stock shaft is working then run it.
    Harley
  9. fliptuner
    fliptuner Registered Member
    Apr 20, 2004
    16
    B.C., Canada
    Either put it towards going to rear disc or bank it and be that much closer to a 60.
  10. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    Hey Andrew! :)
    Rene
  11. la_blazer82
    Apr 12, 2004
    148
    SoCal
    I'm kinda leaning towards disc brake conversion. I'd like a new d-shaft, but that would probably be all the $$ as the HAD shaft if worth some dough. Do I need a diff cover/rock ring if I don't plan on doing rock crawling. Actually I'm not sure, I'm gonna try as many different trails/runs as I can, but nothing too extreme right now since the K5 is my DD
  12. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    Sorry to hijack, but what does a doubler actually do?
  13. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Off road design Doubler
  14. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    if you got no vibes then i'd say the disk conversion would be a good choice. if you plan on a HAD and a SYE in the future, you should do them both at the same time since that will change driveshaft length. it'll cost a pretty penny to do both at once tho.
    hey where in socal are u?
  15. la_blazer82
    Apr 12, 2004
    148
    SoCal
    I currently have no vibes, but that was cured by dropping the t-case. This is the reason why I was thinking of getting a new d-shaft (i want to put the t-case back at the factory height). I live in Pico Rivera, near Whittier.
  16. mxfireman
    Dec 7, 2002
    2,480
    LHC, AZ
    X-over steering would give you alot more for your money than doing a disc conversion. It also makes turning a much easier task than a chore when out off roading.
  17. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    george, where did you get the detriot locker at?
  18. la_blazer82
    Apr 12, 2004
    148
    SoCal
    I picked it up from 4WParts - they matched the $383.99 price from Drivetrain Warehouse (found in that 4WParts magazine). I didn't find much cheaper, and considering I'd be saving $ on buying from the Compton store, rather than paying for shipping from somewhere else, it seemed like a good buy
  19. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    They have a 4WP in Compton??? :haha:
  20. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    That's what I thought when I went to buy my swapers from there. And no it's not in the getto part.
