help me tune this thing!
Discussion in 'The Garage' started by Jonny-K5, Oct 10, 2004.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    heres the stats: 1970 350 chevy, newly rebuilt. HEI ignition
    edelbrock 750 manual choke carb.
    problem: it runs great when cold. but after its been at running temps for 5-10 mins it seems to be either running rich or missing. what happens is if i blip the throttle (idle to 2000rpm) black smoke comes out of the pipes and sounds rougher than when cold. it runs great when driving it,only problem is in neutral and blipping the throttle.
    i've replaced plugs,wires,cap&rotor,coil, tried everything from leaning out the carb 10% to richening it 10%.installed smaller accelerator pump nozzles. i cant seem to figure this one out.choke is manual and wired solid,so i know it not a factor.
    im thinking maybe the ign. module may need to be replaced, maybe my plug wires are arcing over, or something else related to heat soak.
    how should the wires be routed? ive heard that they are supposed to overlap each other to prevent crossfiring. ive also heard this causing crossfiring. what is correct?
  2. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    ttt,anyone?
  3. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    How strong does your spark look?
    I had an S10 that died out in a smokey mannor when my charging system went caput.
  4. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    i havent checked the spark lately. i know it shocks the hell outta me when messing w/ the dist.
    i'll check that tonight, thanks
  5. semper-k-five
    semper-k-five 1/2 ton status
    Aug 16, 2004
    326
    Tulsa, OK
    do you have ur vac advance connected on the left front vac port on the carb?? i had a similar prob and that was the cause....if it were running rich enough to effect ur idle, i would expect some back firing through the exhaust...
    did you use a vac gauge to tune???
  6. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    checked timing again w/ vac gauge, checked spark as well, all good. advance is hooked up to the right port. i think its just more tuning needed in the carb. i'll probly take it to a carb shop and let them tune it and see what they say, thanks guys
  7. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Pretty much the exact same thing I experienced when I put an HEI distributer in my 74. I used the original wire and it ran great until it warmed up. I replaced the wire with a larger gauge from the fuse panel and it's ran perfect since.
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    sounds fat
    lean it
  9. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    really? hmmm, thats worth a shot. /forums/images/graemlins/thumb.gif
    sounds fat
    lean it
    i dont think its too rich, i've leaned it out as much as they suggest in the tuning chart. didnt help, just lost power.
