Help me with excel.
Discussion in 'The Lounge' started by colbystephens, Oct 21, 2006.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    so i want to put two lines on a graph over time. i want two y axes, tho, because one line has y values which range from 0 to .25, while the other line has y values which range from 0 to a few thousand. how do i get a y axis on either side of the graph?
  2. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    anyone? anyone?
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    Once you get the chart up, right click on it and choose "Format Data Series"(or "Chart Options").. In that window you should be able to pick and choose where your labels go and if you want labels at all.. You could try creating a secondary Y axis.. Not sure if it will let you put it on the other side fo the graph though.
    Any links to an example you are trying similar to what you're trying to do?
  4. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    thanks - i figured out how to put a secondary y axis on it tho.
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
