Help me with my PS Pump
Discussion in 'The Garage' started by sandawgk5, May 15, 2006.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I need pictures of the Power Steering pump and bracket from anyone running Hydro-boost with the canned ham rezevoir. I think the mounting brackets are different between HB and non HB as my return line hits the frame and causes the line to get cut when I turn the wheel to the left:doah: . I need to know what to look for when I go to the junkyard tomorrow.
    Ira
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    You need to look for my welder and sawzall....
    On a side note, I just failed SMOG....You were correct when you said those bastards would hit me on not having the little tube thing from the manifold to the breather....
    So now I need:
    -Little tube thingy
    -New gas cap.....WTF??
    -New Cat
    I failed HC @ 25mph by 2ppm dammit
  3. sandawgk5
    Oct 28, 2003
    6,881
    Damn that sucks:mad: . I am below on HC by only 1PPM I think I need a new cat before my next smog in 1 year. I will try to find one of those tubes while I am in the yard. Or you can borrow mine and give it back after you pass smog:D
    Ira
  4. readymix
    May 30, 2004
    6,706
    26
    My cat should be here in 2-3 days, plus a day to install then I will hopefully redo the smog by next Wed. I could stop by the house and get it. That is if they do not have one at CSK.
  5. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Not sure what you mean by "canned ham" reservoir... but here's what I got. Hope it helps.
  6. goldwing2000
    goldwing2000 Guest
    SMOG? Cat? It must suck to live in kommiefornia. :rolleyes:
  7. sandawgk5
    Oct 28, 2003
    6,881
    Nope that is the HB pump I have always seen before. The one I have looks just like a regular power steering pump but it has the 2 return lines for HB and the Steering Box. I need to find a way to rotate the top of the rez toward the center of the engine to bring the return line up from the frame. I might be able to get a slightly longer belt and have to adjust the pump more which would give me the rotation I am looking for.
    Ira
  8. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    so glad I don't live there any more cause the K5 would NEVER pass smog! Now we live in mojave county and there is no smog cr@p here.
