help me with this tranny issue please
Discussion in '1983-2005 S-Series models' started by mudslinger6, Feb 6, 2005.
  1. mudslinger6
    mudslinger6 1/2 ton status
    Aug 1, 2004
    125
    live in ct by the mass line
    i have put a new seal on my tranny pan after the first one blew everything was tightened not to tight and not loose...but i didnt put it into gear and it was slowly leaking???could this be cause by the tripod vacuum line thing that plugs in???is there ne thing that anyone can help me with i sold my primary car yesturday so i need to fix this blazer and get it on the road soon..thanks for the help
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    where on the tranny pan is it leaking? What year and what engine? I am guessing that it is four wheel drive because the vacum lines you are seeing go to the transfer case to shift the front axle in to gear.Did you use RTV on the gasket. How did you blow your pan seal?
  3. mudslinger6
    Aug 1, 2004
    125
    help
    passenger side where the seal is and yes we used silicon gasket,and the seals not broken but its leaking???? its and 89 s-10 and it has a 4.3...the cork one blew becasue i guess i didnt tighten it down enought but this time i got help from a friend who has worked on cars and we checked it after starting it and it leaked...so thanks for the help
  4. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    is it near the front pan on the passanger side? When you changed the gasket did you check for gouges or cracks in the tranny and bent pan or sealing surface? Did you change the filter either of the times if so did you make sure that you got the old filter top seal out it is a common problem for these to get stuck in the pump. Is it leaking bad enough so you can not drive it or is it just a small leak?
  5. mudslinger6
    Aug 1, 2004
    125
    i just went out and im thinking a problem is because its new fluid its kinda hard to see on the dipstick i think we over filled it cause we put and extra quart in and about that much came out....yes i changed the filter both times put new ones in just in case and both olds the rings came with them...thanks does the overfilling part sound right???
  6. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    over filling should not cause it to leak there that area is normally covered in fluid. If you over filled it you need to get the extra fluid out because if it is to full the fluid can be caused to foam up causing damage to the tranny. Also check the seal on your dipstick base that could be leaking and throwing you off
  7. mudslinger6
    Aug 1, 2004
    125
    its not over full because it leaked but once it leaked a little it read good on the dip stick...everthing above the seal is dry but like i said it not leaking so hopefully im good to go...and i dunno if u are into ifs lifts but if so who would be a good compnay to get one for my 10er???and thanks for your help
  8. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    IFS lifts are really expensive for 5 inches it is about 1500 dollars for the kit. To install the kit requries cutting off frame brackets and welding in new ones. If you are only looking for a few inches do a body lift about $80. you can also crank you torsen bars for about two inches with a add a leaf in the rear. If you are looking for large tires yor best bet would be a SFA conversion
  9. mudslinger6
    Aug 1, 2004
    125
    ya i know prices but just asking if u recommended a company that was good....sfa maybe in summer or so....but im looking to run 32's 33's and im looking at a 5 inch lift if not...2inch sus lift,crank tor bars and then spring over in the rear to clear 32's 33's i dont want bigger thats what im gonna but a short bed sfa rig for to lift big...but thanks for your help grately appreciated thanks
  10. mudslinger6
    Aug 1, 2004
    125
    also about how long u say a sfa swap would take???
  11. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    a sfa swap would take a good amount of time. But it is a lot stronger then the crap IFS. The best axles to use wouold be out of a jeep because they are narrower then the full size axle. With the jeep axle the transfer case dose not need to be changed. You would have to fab up sprong mounts and put together a set of front springs. The steering box also bolts up to the steering on the jeep axles. I would figure on a few weeks for the swap working on it part time. The more parts that you have gattered at the start the faster that it will go. I would do a good amount of research before you dive in to it and figure out what your goals are
  12. mudslinger6
    Aug 1, 2004
    125
    ok thanks
  13. mudslinger6
    Aug 1, 2004
    125
    Leaking
    question is there a pressure thing that would keep this tranny leaking??
  14. trailblazer86
    trailblazer86 1/2 ton status
    May 16, 2004
    112
    North Shore of Lake Ontario
    I have some questions about your leak problem.
    Did you straighten the pan surface?
    Were all surfaces clean to the metal?
    Did you use just silicone?
    Did you let the silicone set up fairly firm before installing the pan?
    Did you use the cork gasket and silicone?
    The reason I as is:
    If you dont let the silicone firm up before the install it will squeeze out and cause a leak.
    If you used a gasket with the silicone the gasket will squirm and again leak.
    The torque on the trany pan bolt is around 12 lbs. (I think). It does not feel tight at all and the urge to give it that one more turn is hard to resist.
    On all points I can say "Been there done that"
  15. mudslinger6
    Aug 1, 2004
    125
    i scraped the pan surface put silicon down then the seal let it et for about and hr then i put more silicone one top then put it up and tightened it....thanks but i went away for vacation and my temp plate ends in a few day and i didnt have anytime to work on it so its at a shop...frst time ive ever let someone work on my truck beforee :-(
