Help me
Discussion in 'The Garage' started by pplblazerdude, Oct 13, 2003.
  1. pplblazerdude
    pplblazerdude 1/2 ton status
    Jul 18, 2002
    242
    Kingsport, Tennessee
    Ok i just recently got a rought country 4 inch lift. I was wonderring since the blocks are tapered if ill need any shims and if so how many degrees should i get. Also should i take the overload sprig of the rear to help withthte pinion angles any. Also will i need to drop the transfer case to keep proper length with out getting a new drivesaft.
    Clint /forums/images/graemlins/k5.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    drop the transfer case while you're under there, you wont regret it...
    the tapered blocks should be fine to correct the pinion angle as they're generally designed to adjust stock angles...
