HELP More pinion shaft problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, Mar 2, 2004.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    I got the piece of broken bolt out of the pinion shaft but the thing still will not come out of the carrier. I pound on it but no luck. I budges a little. When one wheel is on the ground the shaft spins with the spider gears, so it is not completely seized in the houseing. I dont know where to go from here. Heat?
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    turn the carrier in the housing so that the end of the cross pin shaft where the bolt goes through, is facing away from you, get a punch, or extension, and a hammer, and hammer on that bastard.. once it moves, keep going until the shaft hits the inside of the housing..then wiggle the shaft back up enough to turn the carrier, grab it with some vice grips and YANK IT /forums/images/graemlins/waytogo.gif
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    How long was this piece? The entire bolt is about 1 inch to 1 1/4 inch long.
  4. zach78k5
    May 14, 2000
    406
    I drilled a hole on either side of the shaft. I got the whole piece. Can the shaft go out either direction or does it have to go only one way?
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    It goes both ways, but sometimes one side is easier.
    I usualy find that pushing the side that has the bolt holding it in is easier.
  6. Confedneck
    Nov 1, 2002
    5,236
    just hammer it out towards the end where the bolt was..
