HELP. Mounting 454 to A 700r4
Discussion in 'The Garage' started by ryanstrucking, Apr 16, 2006.
  1. ryanstrucking
    ryanstrucking 1/2 ton status GMOTM Winner
    Feb 2, 2003
    182
    Calgary AB Canada
    Ok.
    Heres my problem. I have my injected 454 mounted wired and ready to go, I installed the tranny and t-cases tonight but I ran across a big problem when I went to bolt my torque converter up to the fle plate of the 454. THE HOLES DIDN'T LINE UP. The holes on the flex plate are 1/2 a hole to large....
    What I mean is: The bolt patterns are half a hole out........
    What has to be done here, is there a different flex plate I can buy or what?
    Any help would be greatly apreciated.
    Ryan
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Did you get the correct flexplate for 454?
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    GM has a flexplate for the 454 that has both bolt patterns. You must make sure it is for a 454 though as they are externally balanced unlike other GM engines that are internally balanced.
  4. ryanstrucking
    Feb 2, 2003
    182
    Calgary AB Canada
    the flex plate that i have came with the motor. I know like the 400 the bbc are externally balanced and have a different flex plate than a 350. I guess its of to the motor shop todayto see what i can find.
    Regards'
    Ryan
  5. hero
    hero Registered Member
    Oct 21, 2002
    65
    Omaha, NE
    Use a different torque converter. That's what I had to do.
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The torque convertor cost about twice as much as a new flexplate.
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
  8. ryanstrucking
    Feb 2, 2003
    182
    Calgary AB Canada
    Thanks thunder.
    The second link is the flex plate I just picked up today. $50 cdn.
    Off to the garage to r&r the tranny again.
    Later
