!!!HELP!!! MSD blowing fuses???
Discussion in 'The Garage' started by Jonny-K5, Mar 11, 2005.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i installed a used MSD 6A a few weeks ago. works great. this afternoon i was messing with the shifting linkage(other side of engine bay) went to start the truck...nothing. after some head scratching i check the inline fuse to the main power for the ign. box. throw a new one it and fires right up. as soon as i blip the throttle it dies.fuse again. i do this two more times and everytime a blip the throttle it blows. it'll run while idleing tho. what the heck could do this? i didnt touch any wiring. any ideas?
  2. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    anyone?? im clueless on this one. what would make a fuse blow like this? there is no short in the system. i didnt even get close to any wiring. BTW i forgot to mention this is not on my K5, its on a 65 GMC w/ a mid 70's carbed HEI 350.
  3. Fierospeeder
    Fierospeeder Banned
    Sep 17, 2001
    315
    Illinois
    check to see if msd's website has any info on checking the resistance on their ign box.
    does your ignition system have a ballast resistor? sometimes they need to be removed. Are your plugs and wires connected properly?
  4. Fierospeeder
    Fierospeeder Banned
    Sep 17, 2001
    315
    Illinois
    Another thing. Does msd require a fuse? Im recalling back now when i installed an aftermarket box on mine. I think it wanted me to hardwire it straight to the battery.
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I dont have a fuse on my MSD, it wanted it straight to the batt.
  6. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    are you using the correct guage wiring throughout the system. Running smaller guage can heat up the wiring and blow the fuse. Also very tight bends.
  7. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    i noticed in the manual last night it says no fuse needed. i went ahead and pulled the whole power wire and put a new one in straight to the battery, a little heavier gauge this time too. works fine now.:D
    what i dont get is the old setup worked for weeks. then all of a sudden it would pop 30a fuses like it was nothing. owell , at least it keeps running now. thanks for the responses.:waytogo:
