Help! Must prove Dad wrong
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazin'Grrl, Apr 2, 2000.
  1. Blazin'Grrl
    Blazin'Grrl Registered Member
    Mar 24, 2000
    54
    Indiana
    Ok, I posted a question about adjusting lifters, my truck has all the symptoms of needing an adjustment. The lifters are hydrolic, and my dad says they don't ever need adjusted, but it seems to me that they do........am I right? Basically, do hydrolic lifters need adjusting once and a while? even if they're supposed to adjust themselves?
    <font color=purple>Sarah</font color=purple>
    <font color=purple>[​IMG]'83 K-5 Silverado Blazer[​IMG]</font color=purple>
  2. Casey 86K5
    Casey 86K5 1/2 ton status
    119
    Brownsburg, Indiana
    Hydraulic lifters do require some adjustment- but not as often as solid lifters. The only time I mess with the adjustments is when they are making noise. When the engine gets some mileage on it the lobes will start to wear along with the lifters and valve springs. Be sure not to over tighten the rocker arm nuts- thats when lobes start to disappear.
  3. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Casey is right on the mark....
    <font color=green>Eagle86K5[​IMG]
    <font color=red>Only guy I know that can get out of line in a one car funeral
  4. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
